@GradyB It's been a few months. Is it still working? Can you report on on how well it's working? Also, is yours a dual zone or single?
I'm assuming you changed out the Ford plug so it would fit the Dodge plug. Could you tell/show us how you made the connections?
Reason for my concern is it's easy to introduce additional resistance, or reduce same, by changing wire length, diameter, adding splices etc.
Additionally, it looks shorter than the OE probe which will also affect resistance/function.
However, if it works, it works!
Also, which evap did you use? Is that a parallel flow evap? They are supposedly more efficient and have higher capacity, thus changing the ideal amount of R134 in terms of weight. I could be mistaken on this as I was diverted from that research to looking for a prob workaround. Could you tell us how much refrigerant was used to recharge your system?
There is a long (almost a year), but excellent thread about the probe and controler on the TDR forum but ultimately ends with no certain workaround for the probe. The Engineer doing most of the research work on the probe just disappeared about a year ago. So, finding this thread gives me great hope for a viable solution.
Also, it was thought that these probes were made by Bosch. So if anyone has the connections or ability to find out what else they went in could help a lot. Just because Dodge quit using them doesn't mean Bosch quit making them.
Thank you so much for sharing your work and this workaround. I have been pulling my hair out, what little I have left, and reading for hours & hours, looking for a solution.
I will order this probe regardless, just so I'll have it.
It may be a while, but I'll report my own findings here when I'm done.
Again, thanks
Brodie
