coolant temp fluctuating
1.6K views 12 replies 6 participants last post by  bigfish95971
Had my truck since new in 02 and it has always ran at 190 degrees. I've noticed now at 75 mph and 2100 rpm and hit a hill it will climb a hair above 190 and heading back down a hill will go below 190. Then on flat ground goes back to 190. Hauling a trailer it climbs more. I have replaced waterpump and went through 3 thermostats and nothing changed. What could be the next step? Clutch fan going out?
#7 ·
that being oily is likely blowing into the radiator, and causing the radiator to plug up.....
the PH and NALCOOL are elements that determine coolant life expectancy. a heavy duty truck service station should sell a kit to check it. and additive to adjust it. if not....
https://www.fleetguard.com/pdfs/product_lit/emea_brochures/LI33030-GB.pdf
https://www.cumminsfiltration.com/pdfs/product_lit/emea_brochures/LI33021-GB.pdf
https://puredieselpower.com/product...l-coolant-additive-engine-block-cavitation-preventive-1-pint.html#/product/8524
Amazon.com: Fleetguard Coolant Analysis Test Kit CC2602A: Automotive
the first 2 links are information on adjusting coolant health, the 3rd is the NALCOOL, the 4th is the test strips. FleetGuard is cummins. they are filter line cummins makes.
#8 ·
If the oilled radiator is plugged it wont have the fluctuating tempS. They will rise in a hurry and STAY THERE as theres no HEAT TRANSFER. Id replace thermostat and flush coolant. But there again I have vehicles amd known vehicles with over 250k and had NEVER HAD a coolant flush and everything works 100% with run you outta the cab heat. Id put a months worths of wages on that one too !!! So, anyone who says change coolant,thermostat every 20k miles their pieing up a rope !!! Wasting ca$h...... I have friends that drive OTR trucks with almost 700k miles and zero problems. Coolant ph level is within check. Dont know where or how these people get off living by the mechanical "book".
#9 ·
there are those that live by the "dodge said this so it must be true" crowd that follow the schedule religiously. i myself subscribe to the school of thought, "if this was a n14 how would it be serviced." therefore, mine gets mobil 1 delvac 15w-40, and gets the PH and NALCOOL levels checked and adjusted as needed. seriously thought about adding a water filter so i knew it was always in check.....
#10 ·
Reactions: Off-road
#13 ·
The the oil and dirt plugged external radiator core will cause the fluctuations on hills that way due to the varied load on the hills. All you have to do is look closely to check it. Did exactly that when mine was dirty that way.
