WIF light still on after replacing everything.
764 views 9 replies 5 participants last post by  Jhenderson
Hey All, ive got an issue. I know its been covered on here tons of times but each one seems to be slightly different from my issue. 2018 ram 2500 laramie.
I've had my WIF light pop up only once about two months ago. Only for a few seconds then gone. Today I filled up at my usual spot. Its been raining for a few days but i was almost empty so I didn't think anything of it.
WIF light. Has stayed on ever since. drained both filters multiple times. Filled a bottle and the fuel showed nothing out of the ordinary. Replaced WIF sensor. nothing. Cleaned both connections and applied dielectric grease. no change. Tried to clear the code with an ezlynk. Popped right back up. Only thing I haven't done is changed the fuel filters but my dash still says they have 75% life left. Its been raining here in FL for the last couple days and will rain a few more. Unsure what to do next other than the filter change.
Any thoughts? Thanks. Missing my 7.3 right about now lol
#2 ·
This is pretty common on here.
It's usually moisture making its way into the sensor which is triggering it, so you're going to have to tape up the connection really good and see if it works.
Or at least someway to prevent any moisture getting in, it'll be a trial and error process
If that doesn't work then put a little piece of tape on your dash covering the wif light
I too am suffering from WIF alert... I have also changed my filters and drained off several times to find just fuel in there... but will keep trying. I have not seen much about the front WIF sensor but that one looks like a pain to reach so maybe one of the last spots?
Please share if you solve the issue, I will as well.
#9 ·
So, no testing done yet but I did have one enlightening moment after putting my new AlfaOBD reader on the case...it tells me that the WIF circuit is reading HI and that leads me to believe that the input is expected to return back at a slightly lower R level as the probe will have some continuity thru the fuel and allow the ECU to see the expected R value. Also assuming if water was present, the probe is positioned in a spot that would have water collected there first and would read "open" or HI value as the water is not as good a conductor as Diesel and has higher resistance?
Any electronics experts please feel free to add anything here, I am grasping at straws here but, unplugging the sensor circuit altogether gives the same HI reading as I am getting with the sensor "connected"
As I said, further testing will need to be done and a decent connection made to verify anything.
