I have had numerous people tell me different things. A 370 injector vs. a stage 2 injector. Ha will someone please set me straight.
ive heard the exact same thing about the 6.0 powerstroke... the ones in international/navistar products (busses-delivery trucks) had less than half the problems that the fords did.... reprogramming the ecm to ford spec and emissions tuning is what dicked it up...Good point... That's kinda weird the rvs aren't letting go like the trucks are. Maybe the truck vps are built to a different spec, like per mopars request.
ah yes, very good point. I didn't even think about that. So its not really secret tuning, just not abused like the trucks.Same common factor for longevity, in all Medium Duty applications the RPM limit is much lower, and the VP44 used in these applications follows these guidelines.
soo 700hp on stock turbo and injectors......and you "love your cummings". please go outside right now, read the side of your truck, then come back in, and change your sig. hopefully your just joking
Yes, as long as it is for a Cummins application with a 28° incline angle, you can use varying spray angles 140-155°. With some modifications, you can also use a few 8.3L nozzles in the 5.9L application.will any nozzle work in a 12v as long as it has a KDAL59p6 holder and a DSLA145pXXX nozzle? like the 3 or 4 digit number can vary? like: P464--P1174--P263....etc
K - nozzle holderwhats the diff in a KDAL59P6 and a KDAL59P22... it says their both for a cummins 6btaa 5.9...
Won't work, 21mm diameter, 99mm length.and this one here KDEL99P39 DLLA152O496 says its for a ... CUMMINS/CDC 6BTA-590?
all of those are near stock size??the following nozzles would work best, DLLA145 P574 5x0.010", DLLA145 P605 5x0.0095", and DLLA145 P606 5x0.0105".
Yes, good luck finding a hone size much larger without compromising the angle.all of those are near stock size??
Not necessarily, some nozzle holders have the M12x1.5 connector, some have edge filters, some do not.so as long as the holder is a KDAL59P it will work? the numbers after the P dont matter?
Yes, nozzle type, VCO vs Sac type.a DLLA and DSLA nozzle will swap in the same holder? whats the diff in them?
couldnt i just get some 155 nozzles and get a marine kit when i rebuild my engine this summer?Yes, good luck finding a hone size much larger without compromising the angle.
which ones dont have the filters? their kindof a PITA to get out...Not necessarily, some nozzle holders have the M12x1.5 connector, some have edge filters, some do not.
Yes, or use 1st Gen non intercooled pistons.couldnt i just get some 155 nozzles and get a marine kit when i rebuild my engine this summer?
Typically only some of the 1st Gen nozzle holders, they don't need to come out, I've built 5x0.018" with and without them, saw no difference.which ones dont have the filters? their kindof a PITA to get out...
every performance nozzle holder ive seen has them out?they don't need to come out, I've built 5x0.018" with and without them, saw no difference.
Then you haven't seen enough.every performance nozzle holder ive seen has them out?
