Howdy, hoping to get some clarification on the wiring and hopefully help someone later down the road, found lots of information but still confused on a few points.
Fuel shutoff solenoid- I understand it's as basic as 12v to a switch, but is it the lack of 12v or the supply that kills the engine
Fuel shutoff q2- how does the wiring work when starting? My assumption is it should have 12v feed in the run position but where would it get power from during cranking?
Starter- I see two wires one big and one smaller on the starter. Usually when I see this it's power feed and signal, my truck has another solenoid on the fender that feeds the signal. Could this be swapped out with a 40a 5pin relay?
Usually I would test this shenanigans on my own but my wiring and engine are currently torn apart. Thank you.
