Overwriting of tune
1 reading
8.8K views 6 replies 5 participants last post by  StealthDiesel
Hey guys
Just bought a used clean 2010 3500 G56 that has been deleted and tuned by previous owner. Issue is I don't know what tune was used and the tuner unit is MIA.
So now if truck throws a code I have no way to deal with it etc.
anyone know how I might figure it out what tune
Any suggestions for basic tune unit that could overwrite previous tune with new one with little drama issue
Help appreciated
Dave
#2 ·
Without getting a hold of the previous owner there is no way to tell what type of tuner or who's tuner was used on your truck.
Other than that, you will be stuck in having to purchase a new tuner and overwriting what is already on the ECM.
#3 ·
That's what I figured.....any suggestions for a basic tuner that would overwrite current tune without having to go back to dealer to put back to stock? Stock isn't going to work with full delete on truck even for a short ride home I guess
#5 ·
Common situation with buying any used modified vehicle these days.
Who knows what program is in the ECM. If its an 68RFE auto trans, it could even have unknown trans programming.
It may even be worthwhile getting a fresh stock ECM program from the dealer and start completely clean.
Won't that mess with the truck if it's been deleted? Any electronic flash programmer I've ever worked with has to erase the flash chip before it can write new data, it's not like a hard drive, so paying the dealer likely would't have any real effect other than lightening your wallet :)
#7 ·
Flashing a stock ECM program into a deleted truck will set off a ton of codes and the CEL.
However you will be able to drive the truck a short distance if needed.
This will ensure the ECM program is back to a known stock program.
This can eliminate issues when the OP starts the process with a new programming platform.
In the early days of EFI Live, flashing a previously tuned ECM back to stock by the dealer was always recommended.
It doesn't seem to be as much of an issue currently.
