New to the cummins world and need a little help. I have a Van Aaken c3.2 installed, i am just testing it to see if i like the mild power that it should produce. Would like a little more power then stock and this box does just that. The only issue is when i tried it on the high setting which is supposed to be 100hp i believe, once it gets to the high RPM range the truck studders and it soungs like a mis-fire? I gutted the stock intake tube and removed the muffler from the truck and that is it. It runs fine in the level #2 setting and does add some power but on #3 truck doesn't seem to run right. It pulls alot harder but has the studder which i know is not right. Is there something else i need to do or check?
P.S. i know that i need to get guages this opp case first.
Thanks for any help.
