1999 24v NV4500 5 speed, trying to adjust valve lash and need to reach top dead center. I have tried everything short or removing the transmission (again) when I try to use the alternator pully my serpentine belt just slips, new belt and alt AND tensioner. My crankshaft pully/balancer has 4 bolts i a square pattern so i cant put a socket on that. i also tried putting my transmission in a forward gear and turning the rear wheels with no luck i cant get them both to turn the same direction, tried turning the driveshaft as well and that also didn't work. my last option is to just bump the key until i get lucky and it hits top dead center, anything else i can try or something I'm missing?
