tore the trans down and found some very bad stuff. When i droped the pan i found peices of metal laying in the pan, stuck to the magnet, and in a few other areas of the trans. Look like it came from the thrust bearing for the overdrive clutch apply piston. What would cause it to break like that?
When i whent to trmove the complete gear train assymbly from the case it wouldnt come out. The shaft was stuck inside the overdrive clutch piston retainer. And the neck of the retainer is scored very bad. The shaft spins freely but wont pull out. Im thinking ill try to press it out?
When i pulled apart the overdrive unit i found somthing odd, the number of clutch/steel plates along with the backing plate and snaprings are for the gas engine model....... My truck is diesel. The diesel overdrive assymble calls for 2 more friction/steel plates and a steped backing plate with only one snapring. Why would there be a gas set up in a diesel tranny!!!!
Ive attached a few pics, please help me, i need to get my truck back on the road
Edit- im looking online to order a new OD piston retainer but im not sure which to buy, some say they have no governor feed holes, others say they do and some say they come with plugs to plug the governor feed holes
