As title says, I’ve developed this knock sound. Truck in sig, all stock injectors. Had one go about 1.5 years and 10k mikes back. Replaced with new Bosch stock injector from DAP. It’s a very faint knocking sound at idle, definitely hear it from drivers side. When under load, especially when driving alongside for example concrete barriers on drivers side, or through a tunnel, noise is more pronounced. Recently got an oil change analysis back from Blackstone, no indication of out of the ordinary wear for a truck at 105k miles, and no indication of fuel or antifreeze in oil. No CEL or codes related to injectors. I just can’t stand the sound it makes, and haven’t learned enough about the diesel injectors to know when folks speak of injector knock, what is actually happening and/or what it indicates. I’m at the point of being willing to spring for a new set of injectors but would like to know before spending that money that I’m actually going to cure my problem. As for any other indications leading to thoughts of a failing injector, at current temps here @75 degrees, if it sits for a day or three yes there is a faint haze I guess if call it on startup, but again, I’m not sure what startup smoke from a failing injector actually looks like. Are we talking a faint haze or is it actually blowing a blue cloud of smoke at startup? And if the knock IS my only real indication, how close is it to failing to the point of destruction? Do I need to park it until I have new injectors in? Thanks for any words of wisdom. And yes, I know about the search function but it’s really not very user friendly at all on the Tapatalk app in my opinion
