So i have a new set of compoumds on my 12v. A k27 and an sxe369. Hungry diesel fuel pim, m&h timing space, 366 gov spring and hungry diesel lift pump. I have 5x14 injectors in it. I have done a few short test passes and its only pulling 30 lbs of boost. 1000° egts and very little smoke at wot. The star wheel is dropped all the way and the smoke screw is turned in alittle. The power screw is almost at its limit. I built 37lbs with my old hy35 and 5x12s. What are you guys with compounds runnin. Any help is appreciated!:grin2:
