Jaeger build thread - Dodge Cummins Diesel Forum
 19Likes
post #1 of 266 (permalink) Old 07-06-2014, 01:28 PM Thread Starter
Ducati M.
DMan1198's Avatar
Jaeger build thread
Alright I figured it was about time I did one of these for this truck. The story goes that my love of diesels started with my 93 dodge w250 known as The Roo Hunter. I got it bone stock at 16, and loved every minute of it. Over many months the truck gained much horsepower, and got more fun
Then tragedy struck August 10th, 2013 after I killed the stock diaphragm lift pump, and was left without the truck for a week, so I dropped by the dodge dealership, and picked this one up. I decided to call it jaeger because of the movie pacific rim that I'd seen on the weekend
Turned out I actually knew the previous owner, and the only thing that had gone wrong in 74,000 kilometres was one of the licence plate lights had burned out. After a month I decided to order exhaust, but was told I had to save money for school, so no tuner at that point.
Cosmetics ended up being things I was allowed to do, so I did this
Then some LED taillights and some other LEDs made their way onto the truck. Then I managed to sneak a 2 inch lift onto it
Then the fun began, as I got permission to order the tuner to go along with the exhaust I'd ordered 5 months prior, so I got in contact with davemathews and got a mini maxx sent to me with custom tunes
and then I was off to my 1st year heavy duty school, so I only bought a light bar
oh and an exhaust tip.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM3 w/Warp, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan, build thread
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram: dsmdiesel
DMan1198 is offline
post #2 of 266 (permalink) Old 07-06-2014, 03:19 PM Thread Starter
Ducati M.
DMan1198's Avatar
For my birthday I got a set of anzo halo projector headlights.
A few weeks later I decided to put my quick release grill kit from genos' and decided it was time to put my lightbar in the bumper, so I built some brackets, and voila.
then I decided to make my own egr block off plates
I decided I wanted some gauges on the pillar, so I contacted diesel manor, and ordered up isspro factory match 100psi boost, rail pressure, and 2000* pyro.
Then I got my egt baseline with the stock turbo (1900* on a long pull with the tuning I was running) so it was time for more air. I ordered a straight flange steed speed, most of a source 2nd gen swap, and an s467fmw. Then I waited impatiently for my next 3 day weekend. Unfortunately the 467 didn't come in in time, so I took the s480 I'd gotten over a year ago, and decided to stick that on.
I decided to go with manifold studs rather than sticking with bolts. It made the install a lot easier
because I wanted to keep my exhaust a full 5 inches I got a flange and a 90* piece of pipe and modded my diamond eye downpipe
on the 1st of July I decided to pull my ccv cover, and paint it. while I had it off I made the choice to gut the filter.
DMan1198 is offline
The Following User Says Thank You to DMan1198 For This Useful Post:
ehgent orange (07-07-2014)
post #3 of 266 (permalink) Old 07-06-2014, 03:54 PM
Yes Really
frankzappa's Avatar
Wow that looks really good man! Its really coming along nicely!
How is the s480 to spool? Slow?
2012 CCSB - Auto, GDP filter/lines, Pusher Intake, S464, 5" FTE/Flo-Pro, H&S MiniMaxx, Carli sway bar/links, Steps, Flaps, and Seat Covers
OMAHA!
frankzappa is offline
post #4 of 266 (permalink) Old 07-06-2014, 04:03 PM
ooohhh, I really like the way the no-angle manifold flange puts the turbo at a nice height. Not too low, not too high.
Any issues with exh or cold air tube with it mounted at that level?
I mean if you were to do it ALL OVER again would you still with the manifold style you have?
Tomeygun is offline
post #5 of 266 (permalink) Old 07-06-2014, 04:49 PM Thread Starter
Ducati M.
DMan1198's Avatar
The 80 spools a LOT faster than I expected. It's actually fully lit by around 2100rpm.
I really like the straight flange. I had some small issues fitting the 5" pipe (had to pull the heat shield that's on the coolant overflow) to get stop it from hitting, and the water line that goes into the cab doesn't line up with any of the original holes. I did get away with using a straight piece of 3" pipe for the ic pipe, but having a slight bend would be a little easier. If I were to do it again I'd use the straight flange for sure
DMan1198 is offline
post #6 of 266 (permalink) Old 07-06-2014, 04:53 PM
Yes Really
frankzappa's Avatar
Thats great to hear it runs good for ya!
Im stuck on what size turbo to get. Just need to decide so i can join the swapped crowd!
OMAHA!
post #7 of 266 (permalink) Old 07-06-2014, 05:15 PM Thread Starter
Ducati M.
DMan1198's Avatar
It really comes down to your goals. I know I'm going to be putting a lot of fuel to this thing eventually, so I went with something I won't outgrow. I eventually want to swap to a Garrett gtx4508r which is about the same size, but will be a better all around turbo.
On another note I ordered a set of arp 625's and Hamilton valve springs, so I can spin this thing up some more
DMan1198 is offline
post #8 of 266 (permalink) Old 07-06-2014, 05:21 PM
Yes Really
frankzappa's Avatar
Yeah i hear ya! I don't need any extra power past stock fueling. Just get rid of the vgt and have a good tow vehicle that is reliable. thinking s465.
You seem to be heading towards the dark side! whats your end goal? 700 ish?
OMAHA!
post #9 of 266 (permalink) Old 07-06-2014, 05:30 PM Thread Starter
Ducati M.
DMan1198's Avatar
800+whp is the goal with stock bottom end. A 465 would probably fit your goal very well then
DMan1198 is offline
The Following 2 Users Say Thank You to DMan1198 For This Useful Post:
AuggieFIVENINE (07-21-2015), frankzappa (07-06-2014)
post #10 of 266 (permalink) Old 07-06-2014, 05:45 PM
Yes Really
frankzappa's Avatar
Good luck with the goal!
I can't wait to see how it turns out
OMAHA!
The Following User Says Thank You to frankzappa For This Useful Post:
DMan1198 (07-06-2014)
post #11 of 266 (permalink) Old 07-06-2014, 08:00 PM Thread Starter
Ducati M.
DMan1198's Avatar
Thanks. Neither can I. I have to finish my 93 first so I've got a spare high horsepower truck for when this one goes down for bigger work
DMan1198 is offline
trafficmstr (08-26-2014)
post #12 of 266 (permalink) Old 07-06-2014, 08:20 PM
World Champs!!!
MoparProud's Avatar
What's all this "permission" and "told to" crap? Must be married eh?
What's the next step?
'07 3500 SRW QC/LB-6.7 swap-EFILive-Goerend-WOP triple turbo-60% Exergy-Carli Backcountry Project Blue Balls
'03 2500 QC/LB. HO/NV-6.7 Swap-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
The Following User Says Thank You to MoparProud For This Useful Post:
LarrysDodge6.7 (08-07-2014)
