how to lower my dually??
12K views 11 replies 6 participants last post by  kennyhammond
i want to lower the rear of my dually to make it look level ... get rid of the gap between the tires..... but i still want to be able to pull a goosneck trailer when needed
#3 ·
You could remove the rear spacer blocks between the springs and axle they are 4 to 5 inches, assuming you have a 4x4. If that is to much then you could get a set of spacer blocks from a wrecker's and have them milled down to the thickness you want. If you have access to a band saw and angle grinder you could likely do it yourself or get it close so it would'nt take a machine shop long to finish off and get true and parallel. You would likely need to shorten and cut a few more threads on the U-bolts.
If you don't need the carrying cap. you remove a few leafs out of the spring pack.
Can o.done pit a link up I can find the parts at....I looked at eBay and found drop hangers but it said for 1500 and 2500 trucks..... how much drop will I need to get level??
#8 ·
2002 ram 3500 quad cab dualy. 2wd stock tires ...weld in gooseneck hitch...5 speed. ..I am wanting to level the rear to be even with the front ...
#10 ·
i looked under my truck and there is a pretty big spacer block between the rear end and the leaf springs....can i take them out.... or what should i do.. i read that link and didnt realy help that good
#11 ·
As mentioned a few times before you CAN take the blocks out
Look into drop shackles, Also try using the search feature here as there are quite a few threads on this forum about lowering trucks with links and pictures :thumbsup:
#12 ·
mna i tryed searching before i started this..... and i looked at the blocks.... are you refering to the two blocks about 3-4" that are right on the axles... what should i do put the leafs on the axle?
