so im trying to tune in my ve pump to my truck with run as efficent as possible. my sig gives a basic run down of my truck and what power range im at. my dyno numbers are with my old 727 tranny tho.
so today i bumped up the timing to about 1/4 in past stock setting and i messed around with the starwheel. i had it almost turned all the way down, about 2 turns from the bottom so i turned it way out like ive read about doing to see how it runs. with the timing and that i went from having pretty low egt at low driving speeds and having a decent amount of haze to having higher egt's at low driving speeds and cooler egts's at higher speeds but top end power being much better. the smoke seems to have cleared up too at wot.
what i dont get is why such higher egt's at the lower driving speeds especially when i take off and come to a stop. also before when i was coasting to a stop egt would cool down below where my guage stops reading at 200* and stay like that when im stopped. now it will cool down like that but when i come to a stop the egt will climb well over 300*. im trying to get the best mpgs i can out of my truck and i know driving keeping you egt's is the best way to do that but with it acting like this i think i might get worse mpgs since i do a decent amount of driving at lower speeds. im hoping for great mpgs now that i have the 46rh with my 3.07 gears.
it seems like i rambled on a little bit but i hope someone can make some sence of what im dealing with. thanks for any help.
