>>HELP<< First gen runs at wildly accellerated but steady RPMs on startup!
Good morning every one, my name is John and i am glad to be in good company. A buddy told me about this forum. After years and years of looking I finally found a 1st gen dually! When i bought it and drove it home it would die when letting my foot off the gas suddenly from cruise. then when parked it would not even start. At that time my wifes health problems exasperated and eventually she passed on. as a result the truck took a backseat and has been sitting for over 2 years now.
To remedy the sudden dieing and not wanting to start problem, air in the fuel line was likely the problem so i replaced the one foot rubber fuel line going from the steel line coming from the tank and going to the lift pump.
It starts like a champ now, BUT it runs at what seems like high crusing speed with the rpms likely only limited by the governor. bliping the gas pedal has no effect at all, all i can do is shut it off. The throttle shaft in the IP goes from stop to stop without problems and always automatically returns back to idle position. what could be the causes? the VE pump in my Dodge has a cold start module attached to the side of the IP that my Rabbits lack. could it be malfunctioning to the point of producing such high idle RPMs?
I need to get the truck going quickly so any advice is much appreciated!
I have an 1989 non intercooled 6bt first gen with auto. bone stock except for K&N.
Thank you,
John
Thank you,
John
