Hello everybody! I have an electrical problem that I hope someone here can help me with. I have a 2003 Dodge Ram 2500 5.9L. I was driving it a week ago and the thing just died. Upon inspection, found fuse #20 (25 amp) blown. tried a few more fuses but they kept blowing as soon as the key was turned. It sat for a few days. I came back to it and put in a fresh fuse, turned the ignition into the run position and this time the fuse did not blow. However, the fuel pump is not coming on. I know the ignition switch is good cause I'm getting voltage to fuses 28 and 53. According to the wiring diagram; that leaves PTC No. 1. Does anyone know where PTC No. 1 is and if it is replaceable? I suspect that it is embedded on the underside of the circuit board of the Integrated Power Module. Hope someone on here can help! Thanks
Andy
Andy
