I need to install the gauge. Everyone says not to use the isolator? Why not? The instructions from the manufacturer say to use the isolator. What is the reason for not using it? How does the "needle valve" take the place of the isolator.
what you describe sounds like the reason isolators possibly fail. there are a few threads on the forum about isolator failing and leaking fuel.It just came to mind that you might be talking about the "pressure snubber". The VP will send pressure spikes/pulses back through the fuel lines up 150psi or so. You cant see then on a regular pressure gauge but these spikes will KILL your pressure gauge.....
Hope that helps.
