Fluid Damper too thick?
8.4K views 12 replies 8 participants last post by  blacksmoking
Im putting a motor together for a conversion project and bought a fluid damper. But today i put a brand new stock fan/ clutch assembly on and when it threads on to the hub, it hits the damper before its even tightened on.
I measured the stock balancer and the the fluid damper and stock balancer is 1/2" thinner than the flud damper.
What am i missing here?
#2 ·
I had to install a spacer between the fan clutch and it's pulley (slip the spacer on the hub, then screw on the clutch/fan assembly.
I used a large diameter, 1/8" thick washer. Just enlarged the inside diameter to fit the hub.
#3 ·
well its good to know im not the only one. I thought about the spacer idea, just didnt know if it would have any negative effects, but sounds like thats the route il take. You say it only took 1/8" of spacing to clear?
Not trying to change the subject of the post, but was wondering if you can tell much difference with that fluid damper?
#8 ·
Oh....I don't know. Save wear and tear on the crank bearings, crank shaft and the rest of the rotating assembly? Stuff like that :thumbsup:
#9 ·
I drove a guy's 1st gen that had one and you couldn't even feel it running, and mine shakes the screws out of the trim, i was also wondering if others found this to be true.
Dar
#10 ·
Call the maker of the fluid dampner...
Its hard to see in this photo but they make a spin on spacer... Look at my fan blades and how far forward the fan is.
They improve how smooth the engine runs a lot. Like others above I would put one on every cummins I own.
#11 · (Edited)
^ dam that's sexy.:drool2:... Now what were we talking about... Oh fluidampr I run one also and as stated before, it really does smooth out the engine.
Kinda hard to justify droping 4 bills on one... But looking back at my conversion $ #'s it was just a drop in the bucket.
I had clearance issues with the 92 oem aluminum fan...but have just enough room with a newer better designed oem steel fan I'm useing now. Must be a few different fan blade designs out there.
#12 ·
Snoot .....theres no dought about it your engine is absolutly beautiful.
