What kit specifically are you looking at?
Hsp, pusher, hardway etc.
Also what size atmospheric turbo?
What power level can be achieve it all depends on your fueling mods, atmospheric turbo size and primary size turbo.
For example a stock vgt paired with a s475 turbo can achieve 750hp with all the proper fueling such as 10/12mm cp3, 60-100% injectors
With that larger fleece cheetah as a primary and a s480 atmosphere turbo you can achieve above 1000hp on this setup depending on fueling, tuning etc
If going for big power with a compound you'll definitely want connecting rods, valve springs, pushrods, head studs and all that
Pusher arguably sells the best kit on the market for compounds, the strongest support mount for that atmosphere turbo and everything required in the kit along with a giant binder of instructions with colored pictures for each step
