Engine revs up in neutral or park
9.9K views 3 replies 3 participants last post by  ty_5.9
#1 · (Edited)
Hi everyone, I know there are a lot of info on the apps. I have read all of them.
Here is my problem:
Had a P0122 code and dead pedal after replacing the crank sensor because it through that code 3 times. So I just drove the truck for about 2 weeks and then the P0122 code came up, so I reset the apps and started up truck and no problems, idle was normal at 850 rpm. Then drove truck and dead pedal was gone. :) Parked truck and engine starts to rev to 2000 rpm. Turned off engine and restarted. Engine revs up to 2000 rpm again. So reset apps again, start engine and no over rev until I touch the throttle, it then starts to rev up again at idle. When the truck is in drive rpm is at 850 and drives great. BUT in park or neutral its revs up. reset apps again and at first start up does not rev until I hit the throttle then problem comes back and there are no codes. The apps is a
Timbo installed about 1 year ago. Any help on this matter??
Thanks
#2 ·
Have your alternator check at a good rebuilder, not a parts store. It may be putting out bad signals to the ECM screwing it and the apps up. See other threads here.
Reactions: skydiver854
