We towed our 5th wheel to Hot Springs, AR and truck overheated to 245 deg because of a coolant leak at the o-ring in the EGR cooler inlet tube. After repairing the leak and refilling the radiator the truck is fine for about 30 minutes of driving. After a while the temp goes up to 220 to 223 and stays there. After stopping and letting the engine cool I added a gallon of coolant, then drove the truck and the same thing happened. The truck is not running bad and there is no smoke or steam from the exhaust pipe. It has done this 3 times and it takes about a gallon of coolant each time.
Could there be air in the coolant system causing this or what???
