Edge Juice with Attitude Modes
9.7K views 7 replies 7 participants last post by  rquick01
Hi there, I recently purchased a used Edge Juice with Attitude HOT with CTS monitor. I just finished installing it and when I looked on their website it said this thing has like 6 modes. I only get Stock, Mode 1, Mode 2, Mode 3, and Mode 4. Isn't there a Mode 5 and 6? ALSO the previous owner claimed it had been hot unlocked, how can I get the HOT unlock onto this chip OR would it be on there already. This might be some dumb questions but I am just curious :confused013:
Thanks!
#2 ·
Stock is a mode or level and would be number1 then you have 2,3,4,5. You have to purchase level 6 or the hot unlock.
have a hard time believing this....
mine was unlocked its a 4 ditget code that you enter in the monitor, it is not linked or locked to an ecm,
also installed an edge juice hot unlocked on an 05 \(owner bought it second hand from a previous owner who paid for the unlock)
unlock worked on the 3rd gen with no issues
Okay...mixed feedback. Like I said before it only goes up to Level 4. Stock then Level 1 mileage Level 2 Towing Level 3 Race Level 4 extreme. Thats it. The PO said it was HOT unlocked. It's an older chip..looks like I will be phoning Edge tomorrow.
#7 ·
it should be as follows
0-stock
1-mileage
2-tow
3-drive
4-race
5-extreme
6-hot
if the previous owner says he/she paid for hot unlock it will still be there.
#8 ·
^^This is exactly correct. Also, you can go into the settings and adjust the low boost response from 1-5 on each power level. The low boost is basically how hard it fuels how fast, hp gain on each main level will be the same, its just how it gets there. For example, level HOT with low boost response on 1 (aka 6X1) will get you to your max hp gain but will smoke less take a little longer to get there and spool the turbo. HOT with low boost on 5 (6X5) will get you the same peak hp gain but black out the car behind you and spool your turbo quicker.
