Disconnected ECM to replace oil pressure switch and now I have a check engine light
2.3K views 13 replies 5 participants last post by  ColoradoColt
I disconnected my ECM to replace the oil pressure switch and now the wait to start light takes atleast 10-15 seconds to come on and I have a check engine light but no codes? Any input would be much appreciated!
Thank you.
#2 ·
Why don't you start by telling us some specifics about your truck. How are you pulling codes? It needs to be done with a scan tool, then get back to us. You will have some sort of code if you triggered the cel. Why did you have to disconnect your ecm?
#3 ·
The truck is a 1999 2500 4x4 slt 6 speed. I had to disconnect the ECM to be able to get to the oil pressure switch, I don’t have a scan tool but I took the truck to autozone and Midas to use their scan tool and they were not able to pull any codes! They scanned the truck multiple times and still no codes the only thing the guy kept telling me was that the scanner was not able to get a connection or a reading from the body control unit. Also the truck did not have this problem before I replaced the oil pressure switch.
#7 ·
if the bats were still connected when you disconnected the ecm I believe that would trigger the cel
#8 ·
delayed wait to start does not bode well for your ecm either
#13 ·
The wait to start indicator is directly controlled via the ecm. A delay indicates an ecm problem unfortunately. Hopefully a better connection with dielectric helps but not likely imo
#14 ·
Exact thing happened to me when I replaced my bad ecm. My ecm had symptoms before going out tho. So I doubt yours just happens to go out after unplugging it. After I installed my new ecm I got a CEL, and wait to start never came on. Cleared codes and put on dielectric grease, and wait to start came on for about 20 second, after about 20 seconds. Ever since it’s came on right away like it was supposed to. If you do need an ecm I recommend
I got mine from them and even had it overnight shipped for cheaper then most places.
