Hi,
Thanks in advance for your time.
Getting P2121, P2122 DTC's? Dead pedal?I have repalced the wiring as well, and am still having issues....
I’ve gotten a p2121 p2122 and I think a p0222 or something like that one time, I get dead pedal, or recently it’s actually been I can only get 1/4-1/2 throttle out of it then it starts bogging and missing, that only will last the remainder of the drive then it is fine on next startup, like I said I could never get the brake to work so I took it off anyway, but the problem only happens when I use cruise control since I got rid of the brake, the brake was tapped into a yellow wire right off the ecm plug, and two wires under the steering wheel,04.5 manual transmission 325hpSo your other threads on this issue confirm that you do have an under battery APPS and that you also have a BD exhaust brake that taps into the APPS.
And you are getting several APPS DTC's and serious APPS failure symptoms.
Strange coincidence as I also have a BD exhaust brake that taps into the APPS.
I wonder if OP, Jules, also has a BD exhaust brake?
On the older trucks the BD exhaust brake used an adjustable APPS module "trigger". It's a high impedence voltage sensor that is monitoring one of the APPS signals to trigger the ex brake.
I tapped into the APPS wire near the driver's side battery, T'd in, soldered and heatshrink.
I get an APPS P2121 about once a year on my 2004.5. No symptoms, just a ding and CEL/DTC that I clear with my Smarty.
It happens so rarely in my truck that I don't recall what the conditions are when the APPS DTC is set.
Instead of removing your BD ex brake, I would disable the BD APPS module and just run the exhaust brake on the master switch manually.
Most guys run their exhaust brake manually with a switch on the gearshift shaft.
This would eliminate the BD ex brake APPS module.
Then I would be shopping your local autowreckers for a 2005-06 1500/2500/3500 truck and remove the pedal APPS sensor, bracket and pigtail as I did above.
By chance do u have a link to one that will work?Yes. Very easy.
Then unbolt brake master from inside and pull out, and unbolt box itself and pull out.
Only need to swap plug on motor…
