Bullseye turbo questions
1.1K views 7 replies 4 participants last post by  Stormin08
Hello, I bought a wrecked '01 to use the engine and auto transmission in one of my other trucks. The truck has a very low mile, almost new Bullseye 62 turbo, from what I can tell on the papers for it, it is a 62/65 with a fmw compressor.
Anyone have experience with these? Are these a decent turbo?
Also, I'm not sure on the housing size as I don't see a casted or stamped number on the housing but I may have to get a mirror to see the bottom better, being it's on an auto I would guess maybe around a 12 or 14cm?
#3 ·
Ok that's good to know. On the paper, all it says about the housing is T-3 .80
When I get the truck put together I plan to be able to tow with it when I need to and probably wont be using a high hp tune much. I believe it's supposed to have 100hp injectors in it, also has a s&b filter and box.
#5 ·
You may want to spurce a 12cm turbine housing for better towing. Unless it is all hiway towing.
Reactions: W350_1992
I'll keep that in mind, I probably won't be towing super heavy but I mainly just want it capable when I do need to tow something. The truck it will be going into has 4.10 gears, would the 14cm housing be beneficial with the higher highway rpm's vs a 12cm in that case?
