I made a make-shift boost leak tester today out of PVC, and charged the system to 10 PSI.
Found multiple loose boots on the IC piping. Fixed via soapy water test.
I sprayed all around the AFC and the tubes from the intake and that all seems good.
I juiced it up to 15 psi. I can hear air moving behind the fuel filter/engine?
I juiced it up to 20 PSI. Boost gauge stayed at 15 psi and I just heard what sounded like air moving (not a hiss, but air movement) again behind the fuel filter/ housing/engine/firewall area.
What the heck? Do I need to turn my engine a bit? Could it just be a valve open or something? No air seemed to be coming out of the tailpipe...although I'm not sure if I'd notice anyway. If it was an intake valve, could it be recirculating?
Not sure where to go next. Blew the cap off at 20psi and it scared the heck out of me. Ha
