Amp usage for Glowshift Gauges
7.9K views 2 replies 3 participants last post by  stodg73
Finally getting around to wiring up my glowshift gauges. Anybody know how many amps your typical gauge uses? also i plan on wiring the switched 12v power for all four gauges to the same spare slot on my fuse box, just wondering if anybody else has all their gauges wired to the same circuit.:confused013:
#2 ·
I have one ground and one power source running to 3 DiPricol gauges, and once the wire is in the a-piller and just tapped into the power source. the lighting is all LED so that help on my account, I tapped into fuse for interior lamps 10A
Reactions: Josh88
#3 ·
On mine I tapped the gauge cluster 5 amp fuse on the inside fuse panel and am using a 5 amp fuse. They don't use hardly any amperage.
