I am planning to get rid of the heat exchanger eventually, will leave the coolant connected for now.
My existing OEM AT cooler is stuck in bypass mode, so I have to pull out thermostat and fix it, one way or another, the thermostat is going away, may use a ground bolt and rubber oring instead.
I have 15 feet of rubber oil cooler hose, which I wont need all of that.
But since I am getting rid of heat exchanger, and may tow someday, I wanted to add in more AT cooling. OF course as cheaply as possible.
I found various interesting options.
The Ford 6.0 26 or 25 row AT cooler will fit, not the bigger 31 row cooler.
example here shows the height is 13.5 inches, width 21.5 inches, useable height on truck is not more than 17inches, and the rubber hose has a 3 inch bend radius.
Then there is this, which looks like there is also room for that, and people like it.
My Amazon Ford cooler sale got cancelled, they dont have any, Rock auto has a 26 row GPD cooler for $149
But when looking through the sales, I found a warehouse Amazon deal on the Dorman stock cooler for the truck at $39 instead of $140! SO I bought it.
There is plenty of sideways space to fit another AT cooler in front of the existing OEM cooler.
I plan to run the two coolers in series. Will cut some of their tubing and connect rubber hoses to make that happen.
I am still thinking which cooler to place in front or behind the other. The new Dorman will keep its thermostat, the original cooler, the bypass will be blocked. I am thinking put the Dorman in the oem spot with its input coming from output of trans, and put the old cooler in front. What I do may depend on how they nestle together seeing the Dorman has slightly different looking mounting brackets.
