Im trying to trace down a problem and i think these two might be related.
Truck is a '99 Excab 4wd 2500 5spd.
1st off, ever since i have owned this truck, there has been a vibe/shake at just under 45 MPH.
Coming from the rear of the truck. Its not a sharp vibe but more of a wobble... like a big mud tire out of balance.
Thought it was the tires, i rotated them and balanced them at work... actually NONE of the tires were balanced.
Truck rides alot better, but still there is that shake thats coming from the same spot.
I checked the dshaft, all the weights seem to be there.
Would a u-joint cause this? And what about that middle bearing thing there on the front shaft? I can move the shaft around in there. Looks like is surrounded by rubber... Ive never owned such a long truck, so i dont know what thats supposed to be like new.
secondly, when i upshift, windows down, i hear this clink and clank when i let the clutch out. Dosent do it all the time
deff sounds like a drive line clink.
is this normal on these nv4500s?? Ive owned several stick shifts and non of them made a clink or clank when up shifted.
could a ujoint be the cause of both of these??
