Hey all, new to the forum. over the weekend I studded my engine, all went smooth but I'm at the point of re installing my rocker assembly and have had no time to continue on with the rest of the re-assembly as I have been so busy. Had a question about the rocker assembly install
upon disassembly of the valve train I removed all the rockers and laid them out as I took them out. Is there anything I should be concerned about when re installing? after i took them all out I rotated the engine to TDC not sure if I'm at TDC 1 or TDC 2 probably should have done so before removal so i am yet to figure that out. When it comes to torqueing the rockers down I'm concerned about a piston kissing the valves? Should I be? I have not messed with any of the adjustments on any of the rocker arms. so should I be concerned about that?
Thanks!
Thanks!
