4x4 conversion on a d350
28K views 12 replies 6 participants last post by  12120
I've tried to search this but what would I need to make my d350 a w350? A complete front end? This is just in te thoughts stage but if it seems simple enough and I can find the parts I might go through with it. Any comments and it suggestions
Thanks
#2 ·
a complete rolling part'struck with following front spring hanger's and rear front spring hanger's 4x4 engine cross member and then your choice of tranny .everything else you already have .
#3 ·
The steering box is mounted different on a 4wd from what 2wd's have. If you leave your box where its at you can do crossover steering which rids the truck of the nasty bumpsteer which is soon to be my next mod as I already have the heims and tubing ready.
Yeah I forgot about box OOPS but like said do cross over steering and throw that stupid plate away
I would say a 8 just because of how extensive it would be. But if you got the time give her he$%..
#7 ·
I would say 6-7 If you have the time to tear it down you can put it back together really easy when your ready send me a PM and a e mail address I will send ya some Pic's of how it's done .
#10 ·
Sure it's easy to do swap front susp. out convert it over to 4x4 I think that's the hardest step you will get Real close with a 1/2 in drill n Bit eat your wheaties your going to need it . but after that pretty much everything bolt's back into Place .
