Let first start off with i am a master honda tech for 20years, with that said, need a experience dodge tranny guy for help on advance diagnostic on 06 ram 2500 5.9 cummins with 48re, I have an issue with my transmission shuttle shifts into third around 40-55mph, and at time will will code up p0720 transmission output sensor failure, so with the montior graph on my snap on solus for transmission outsmart speed, show the valve would increase for the most part smoothly up until reaches roughly 40-45mph then you start to start jumping up and down as the speed increase, so far what I've done is had the pcm rebuild by ecu computer exchange, replace two after market transmission output shaft sensor, both sensors would run good for few weeks and go back to the same problems, got a mopar one now but have not installed it yet, due to the fact that when I test the original one test stated that the sensor is still good, i also check when I check for the wires before I had the pcm repaired and did find 2.5 volts on both wires to the transmission output speed sensor connector when connected to ecu but shows no short to any wires to the wire going to the pcm, been fighting this issue for pass 6 month and I've exhausted my resources
