At 37* it should start without grid heaters, you should hear a click coming from your left fender well when you turn your key on. If not either ECM, wiring, Air intake sensor, or solenoid problem. You can operate the solenoids with a push button to get you by until you find your problem. The small wires on the front sides of the solenoids are ECM ground make them body ground, the other small wires on the back side are ECM hot, make them hot with a push button switch.
