Can someone explain what the benefit is using the EB during a cold start/ when the truck is at high idle right after starting during cold temps..
It helps warm up the engine, but not because of keeping exhaust heat. It blocks the exhaust partially which puts a load on the engine which causesIt keeps some exhaust heat from escaping which helps warm up the engine a bit quicker.
Jason
You ought to hear it with a 5" stainless and no muffler. Sounds like a F-14A on burner waiting to be launched off the deckI don't know about everyone else, but after I put a 4" tbe with no muffler the engine break is pretty loud and obnoxious, espesially at warm up idle. It doesn't bother me as much under a load but it sounds like a super hair dryer on crack at idle, not sure if you can do anything about it other than adding a muffler...
