fire rings require a special cut head gasket, and are not generally used for a street truck and can fail and damage the engine.
stock gasket + :
425 Head studs and head bolts can hold well above 60psi but only if you torque properly to 125ftlbs.
extreme studs /bolts can hold more
625 studs can hold even more
adding Orings to block or head can add quite a bit of capacity and are safe for daily driving and many thousands of miles.
using a +10 or +20 gasket will lower compression slightly allowing even more boost to be compressed but will lessen low-end response, lower over-all efficiency and make starting harder.
There are specific factors that will cause trucks to live/fail with the same gasket and/or studs, such as miles, heat, timing, injectables, quality of machining, luck, ect.
In my own experience a stock head gasket with Oring'd head and ARP 425s held 90psi bursts often for over 3 years.
My new engine has +10 gasket, ARP625s, Orings, and will see 100+psi.
Note: I never work the truck hard before its up to temp and the Tstat is open. I also made sure the Orings were bedded-in properly with 3-4 retorques on them before the first WOT run.
