turning engine over for valve lash
1 reading
20K views 29 replies 11 participants last post by  GRUNT 11B
Any one find an easy way to turn the engine over for doing the valve lash? I dont wanna have to crank the engine over and over till i get it at tdc.
#2 ·
When we just did my stepson's, I just laid under the truck and used a pry bar on the the fly wheel while he watched the marks on the balancer. Skeeter
#3 ·
barring tool is the easiest way, it goes in a hole on the passenger side below the turbo on the transmission adapter plate, there is a cover over the hole. I think i paid $35 for the one i got. What i do is put it on TDC then i painted an orange line at BDC so i can see it from under the truck.
I just looked on ebay for the tool 2005DFS mentioned.....see OTC Cummins Engine Barring Tool 7471A | eBay
I'm going to have to get one of those! I'm sure that would be easier than the pry bar through the trans bottom bell housing opening. I like that paint idea too....:cbadge2:
#5 ·
Ummmmmmmmm...I think I just put a breaker bar on the dampener bolts. Or the alternator. Sorry, can't remember.
#7 ·
I pull the plastic cover for the injector pump bolt and turn it there , super easy and can do it all with out moving. Just make sure you go clockwise
#14 ·
That worked for the first two turns. Then the next few turns nothing in the valve train moved. So i figured i better stop.
#8 ·
By the time u install the barring tool I'm half way done with valve adjustment
Reactions: Big Swole
#9 ·
I need it done by Monday since I'm getting efi live then. So i don't have time for the barring tool, other wise I would have ordered one of those. I'll remove the plastic cover on my alternator and try that.
#11 ·
Well my alternator doesn't have a bolt in it. There is a hole with what looks like spider gears around out. Put my finger in there and don't feel a bolt head
#12 ·
Check dampener and use one of those bolts. Nice and slow is the deal.
#13 ·
What is the dampener?
#15 ·
The injector pump bolt will turn the whole motor no matter what , its all gear driven . You were turning it like you would be tightening the nut right?
#17 ·
Well i think i earned the moron of the week award. Forgot to take the truck outta gear
#16 ·
Yes, i was going clockwise. I don't know if the nut or bolt (which ever it is) was just tightening or if something else was going on since nothing in the valve train moved for a few turns
#18 ·
I use a 15mm socket and use a balancer bolt. But when I redo the motor I'll be putting fleece's crank tool.
#19 ·
I just laid under truck and grabbed the dampener and turned it by hand, well it took both hands. But I was able to watch the mark as I did it pretty easy.
#21 ·
I used the nut on the timing belt behind the injection pump. It worked really good
#24 ·
Behind your injection pump is a round black plastic cover. You remove that with a 3/8 ratchet and then behind that cover is a big nut, I think i used 1 1/8" socket. You turn that nut clockwise and it turns you're engine over.
#26 ·
I don't follow what you are saying. the first quote is what I did, the second quote is exactly how to do it.
#28 ·
Oh haha. Well the timing gear, chain, rubber band, flux capacitor. Whatever happens to be in there, i don't know. But that's the thingy i used.
#30 ·
Now I've learned something new, thanks
