do you adjust the voltage with the key on engine off or just key off totally? I'm reading different things.. is there anything to confirm the .545v im adjusting it to??? is this the remove negatives, pump pedal thing?
my friend is saying do it this way... exact sequence..
1. remove negatives from batteries with key on
2. pump gas pedal 10x
3. re-connect batteries
4. set/adjust TPS sensor to my .542 volts
5. pump pedal 10x again
6. start truck
is that correct?
No voltage Adjustment!
Mopar1973Man's Dodge Cummins Articles - APPS Sensor Voltage Adjustment
The fact is that the stock APPS sensor is a rheostat yes. But APPS sensor is set at a particular voltage for the electronic switches inside that reports to the ECM if it at
IDLE or
THROTTLING. If the APPS sensor voltage rises above the voltage listed on the tag the switch changes to
THROTTLING. Then when the voltage drops
BELOW the voltage on the tag then the ECM switches to
IDLING. This means the APPS sensor voltage is disregarded and idling software of the ECM takes over control of the Bosch VP44 injection.
NOW... The Timbo APPS sensor... There is no set voltage tag because the switch for
ON IDLE and
THROTTLING is mechanical this means once the APPS sensor bellcrank gets to a particular angle
THROTTLING starts regardless of voltage. So there is no voltage to adjust the APPS sensor to just a matter of taking the slack out of the APPS sensor bellcrank.
So now you know why you
DON'T set the APPS sensor for
EXACTLY the tag voltage because now the APPS sensor idle validation switches will constantly flip back and forth between
IDLING and
THROTTLING causing issues with exhaust brakes, high idle software, etc.
It's not about the voltage, it's about the fact of the APPS sensor Idle validation switch state...
Problem #1 - Voltage on label
Everyone is trying to hit APPS sensor voltage dead on what's on the tag...
DON'T! This is the voltage that the APPS sensor goes from ON idle start to OFF idle state. You voltage MUST be
BELOW this number.
Like on mine the APPS sensor voltage is .519. Don't set the voltage at this set it below this mark say .480 to .490 because as you add in voltage gain or loss during normal operation of the truck it might cross the mark and go off idle and you end up with idle set at 950 to 1000. Then find out your exhaust brake, high idle and a few other things don't work!
WARNING! STOP! Don't set the APPS sensor voltage to the voltage on the label this is WRONG!
Like the Timbo APPS sensor you adjust to to the point you cross the dead zone and back off below this point 1/2 turn. Reason why is to keep the APPS from accidentally going to OFF idle state. As long as the voltage in the APPS sensor is below this state the the ON idle signal is given to the ECM and the APPS signal is basically ignored and idle programming is used.
Now if the alternator or voltage of the system change a little bit you going to have issues of the voltage crossing back and forth over this boundary. Please set your voltage
BELOW what on the tag by about 0.2 volts to insure the voltage is low enough to put the APPS sensor in ON Idle state. If this was my truck to set I would set the voltage for .480 volts at the APPS sensor plug.
