timing and smoke?
1 reading
13K views 12 replies 7 participants last post by  jake17201
Do you guys remember Marco saying anything about taking out some of the safety features of the smarty to make it run cooler and smoke almost extinct? On tnt lvl 7 i get about the same puff of smoke i get on the BDDL loaded with the performance setting. Cl smokes like a freight train. Does more smoke mean less timing advance which would mean that CL is relatively safer as far as too much timing goes? I understand they are both bad for your engine if you are stupid but what about just general timing advacement?
#2 ·
I read somewhere that at MAX TORQUE a more advanced timing smokes more. At lower torque a more advanced timing smokes less. I don't know if this is true or just some BS I read on the internet......somewhere......:confused013: anyone know anything about it?
#5 · (Edited)
you can have too much timing, but the advances that are made by the smarty or bd is not damaging as a whole, as long as you dont stack boxes/programmers that both add timing, also remember the more advanced timing you have, the cooler your egts will be, but over advancing you will melt a piston.....
good specs to go by when advancing timing...
Advancing the timing will...
Decrease exhaust temperature
Increase cylinder temperatures/pressures
Increase fuel economy (yes, economy is better)
Increase your output of NOx (a pollutant)
Decrease your output of Hydrocarbons (a pollutant)
Increase the amount of black smoke at peak torque
Raising the cylinder temperatures/pressures after already having increased the fueling pushes the engine that much closer to its design limits, but lowering the exhaust temperature helps balance against the increased heat load from the increased fueling
Engine parameter: TIMING is:
.............................................RETARDED ( - ) ADVANCED ( + )
EXHAUST TEMP.................................. increases-------decreases
CYLINDER PRESSURE........................... decreases-------increases
INTAKE MANIFOLD PRESSURE
(BELOW P-TORQUE) WASTEGATED....... increases-------decreases
BSFC (brake specific fuel consumption)... increases-------decreases
NOX (oxides of nitrogen)...................... decreases-------increases
HEAT REJECTION................................ increases--------decreases
HYDROCARBONS (HC).......................... increases--------decreases
BLACK SMOKE: 1000RPM..................... increases--------decreases
BLACK SMOKE: PEAK TORQUE.............. decreases--------increases
BLACK SMOKE: RATED........................ increases--------decreases
WHITE SMOKE: < 1000RPM.................. increases--------decreases
WHITE SMOKE: > 1000RPM.................. increases--------decreases
Reactions: milldog
also remember if you go beyond 15* of timing the engine noise will rapidly increase and you will see more abundant black then blue smoke.....
#7 ·
How much of a timing advance before the burning fuel starts resisting the rise of the piston at the end of the compression stroke?
