I am putting a new head on my 1990 12 valve, and I am wondering about a different thermostat. I have read about using different temp thermostats, but my question is more about the way the original one functions. I read about the original thermostats that would cycle just a small amount of coolant at first, then open up fully, causing the temp gauge to fluctuate. If I am correct in this description, why did they operate that way? I am also looking to replace it with a "standard" type thermostat that I have found for the Cummins, that says it will not operate that way, and will operate like a normal thermostat without having major temperature swings on the gauge.
Truck will be getting 370 injectors(non intercooled pistons), fuel pin, 3200 rpm spring, intercooler, HE351 turbo and possibly a Fass lift pump.
Not going to pull that much that often.
