I have a slight leak where the transmission cooler line connects to the quick connect on the thermal bypass. I am trying to troubleshoot the issues and come up with a way to fix it but don’t really understand how the quick connector actually seal. Does the tip of the hard line seal or is it the v shaped flare? The larger v flare on the line is slightly bent or deformed, this likely occurred when I installed the thermal bypass. Below is a pic (found online) to highlight the hard line flares and for reference (one of the flares in this photo also looks less than perfect) at the bottom is a pic of the actual leak. Leak is not coming from the threads that connect the quick connect to the thermal bypass.the leak is a drop or two every couple of stays but it’s enough to notice on the driveway.
