Hey guys as the title states i have a p0341 code on my truck which is a ;
2006 MegaCab 5.9l Cummins
Auto
Slt
257000kms
Only mod is removal of the silencer ring in the turbo.
And the story ;
I bought the truck 400kms away, ran great however needed new injectors(chattering on return).
I test drove the truck and everything worked great, no sounds / shakes / lights etc
As i was pulling into my home town after driving 400kms , coasting and idling down the street i got the code for the first time, the truck still ran great absolutely no change in performance etc.
It cleared itself eventually and about a day or two latter it came on again, and again and again, off on off on about once a day.
-I changed the cam sensor and to my dis belief it starrted comming on and off more erratically.
-I changed my injectors/filter which was said may be the problem, nothing (had to do anyways)
-i changed the crank sensor , nothing
- i checked for chaffed wires, nothing
- i disconnected the command start wire to 5v to restore te 5v signal, nothing
So now im at a stand still.
Im thinking next things to check are the ;
Batteries (low volt signal going to sensors)
A/c sensor (possibly affecting 5v signal)
Camshaft endplay (i really hope its not this one as im assuming its expensive)
Bad ECM
Codes Stuck in ECM (maybe i fixed it and the codes wont clear)
But the weird thing is it seems to have gotten worse as in it is coming back faster and faster, im at a stand still as the truck runs and drives awesome but this code wont stay away.
This is my first diesel/cummins so im a bit slower at wrenching but i am extensively mechanically inclinded. Diesels just sort of intimidate me to work on.
Anyways thanks for listening and hopefully someone can help me out with this, aswell as thanks for finaly letting me sign up CUMMINSFORUM, i no longer must seem like a threat as today you allowed me access.
Thanks
Auto
Slt
257000kms
And the story ;
Bad ECM
Thanks
