As much as this has been gone over I'm sure everyone knows that the problem is the alternator leaking AC voltage into the system. The first problem is the parts store alternators are junk most of the time.
My truck started having the lock/unlock problem 2.5 years ago. I started digging into the problem and checking things on the truck. Well before I bought the truck someone had installed a BD noise filter on it and that obviously didn't fix it. So I moved the ground wire away from the alternator just to see if that would fix it. It was a little better but still had the problem. So I bought an alternator from Advanced auto. It was fixed for about a month and it started again. I took that alternator back, got another one and again only about a month with no problems until it came back. At this point figuring out that I was just gonna keep getting junk from any parts store I took it to the only competent starter/alternator rebuild guy in my town who was about 60 years old. I asked him to check the diodes and if any were bad replace the whole rectifier/diode assembly. He called me back said that one was giving off a different reading so he replaced it. I think he charged me $50 or something to fix it.
Stuck it back on the truck and its been fixed for a little over 2 years. Well the other day I was driving it and it did it again a couple times. So knowing what the problem was I just pulled the alternator off and was going to take it back to the guy to do the same thing. Well he's closed up business and retired. With no other choice but to figure it out myself. I took the 4 nuts off the back cover of the alternator and there it was. I removed the 2 screws holding the brushes in and then removed the 4 screws holding the rectifier plate in.
I called these guys https://www.aspwholesale.com/ And ordered a new rectifier/diode plate for my year model with a 136 amp alternator. Only cost $33 plus $7 for shipping. It only took 2 days to get to me and I put it all back together and on the truck in less than 30 mins.
Problem solved! No going back and forth to the parts store 10 times to keep getting junk. Just call those guys and order the part you need and fix it yourself. If you can change oil you can do this.
The part # for the replacement rectifier plate is Transpo-CN INR734P-1945
The biggest thing I don't understand is what causes these things to go bad? Does anyone know?
Here's a pic of it taken apart.
