Stock Alternator Size?
1 reading
16K views 14 replies 8 participants last post by  DannyMK2
What is the idle and driving amp rating for a 3RD Gen stock alternator?
135 amp sound right?
#2 ·
i know they put 136 amp and 160 amp in the 5.7 hemi's
so with the diesel having 2 batteries i would guess that its 160 amp, but im not 100% certain.
#5 ·
I'll check tomorrow, my truck is parked at work
It should be on the alternator near the serial/model number, correct?
#7 ·
my next one i am going with the 200amp replacement...
#8 ·
According to my VIN and the truck's build sheet:
BAZS 136 Amp Alternator
#10 ·
XDP has high output alternators. You could also look for someone in your area to rewind your current one for more amps too.
#12 ·
Anyone replace their alternator with a higher amperage unit?
I have contact two diff business' and both said the charging cables all need to be upgraded.......
I was hoping for an bolt on upgrade!
#14 ·
Can I just replace the one charging cable from the alternator to one battery, or do both cables on both batteries need to be upgraded?
#15 ·
i honestly havent payed attention to the size of the wire connecting the two batteries on my thrid gen, but on my 2nd gen the wire was massive, while the alt cable was smaller. if thats the case, you may see a difference just upgrading the one, but if they are both small, do them both. also, dont forget the ground wires. those are important as well. you may even want to consider adding a ground cable for the alternator. seems like a lot of work but it does make a difference.
