I've been messing around with this for months. I need someone to correct me if i'm wrong.
# 0 - Default
# 1 - Stock
# 2 - for aftermarket injectors
# 3 - for Hugh aftermarket Injectors ( less timing advance than # 2 )
# 4 – for use with NOs ( less timing advance than level # 3 )
With those settings coming straight from mads.
So #1 is stock timing and #2 is advanced timing. If #3 has less timing than #2. And #4 has even less timing than # 3. As fallows should be ture.
In order from most timing to least timing. #2,#4,#3,#1.
So if i'm running #2 now and dont like the way the truck is running i can run #3 or #4 and actually be closer to stock timing and should have anything to worry about?
# 0 - Default
# 1 - Stock
