I put air lockers in pickup and rear one does not have the tone ring on the carrier for the sensor, the one on the top of differential. Then it set off the abs and bake light when it does that then the transfer electronic shifter will not shift unless you turn it to 4L then back to 4H. Then when you turn it to 2W it will not shift until you push the neutral button, then turn it to 2W. If I clear the abs and brake light codes out then it shifts the way it is supposed to until light come on again. is there something I can do with that sensor to trick it . Thanks
