Propane setup?
1.6K views 7 replies 6 participants last post by  LIL JOSE MIAMI
I heard about a propane setup for $500 and im curious about propane systems now. if theyre good for mileage or what theyre good for? how much is a good set up? anything?
#3 ·
so whats it take to hook it up? and is it good for the engine?
it doesn't hurt the power right? otherwise whats it good for if the mileage isnt helped much?
Propane was good for power before everyone realized how dangerous it could be. It will definitely improve your mileage and increase power, but like I say, it's dangerous, and filling the propane tank can cost as much as a tank of diesel in some places. Try it out, it might work for you if you get it dialed in right.
#7 ·
I've heard it can have a cleaning effect on the engine, probably for the same reason it can blow headgaskets. This thread is the first place I've heard about the HG popping characteristics, but I have used propane and think it did have some cleaning effect. I didn't notice any MPG change but it would definitely idle rougher. Although I had a pretty basic setup.
I used a 20 lb propane tank with a simple regulator set at about 60 and a needle valve to adjust the flow. The problem is that you have to remember to open the tank after you start the truck and before you shut it down. Or you'll get an intake system full of non-oxygenated gas and it won't start until it has pumped oxygen in.
Here's where I originally read about it: Precombustion Chamber cleaning?. - PeachParts Mercedes ShopForum (post 15)
#8 ·
HI, ill be interested in getting that propane kit off of you if your interested in selling it.
please give me a call my names Joe 76-340-2505
