My company buys my trucks for my job. My 2002 dually cummins went 305k miles before they made me get another truck. I went through 1 clutch, a master cylinder, and around 4 brake jobs. It was a dependable truck. I had it serviced at dealerships regularly. Never used oil, a/c always worked and never left me anywhere.
The company manager was new and wanted gm. So they bought me a 2005 dually duramax. The radio cd player quit on the first cd. All the switches on the drivers door panel quit working whenever it rained. I had to have 2 fuel pumps installed, the fuel mileage was NEVER over 16mpg not towing, towing it was 9 mpg. injectors had to be changed twice, dash started peeling in the first year. went through front tires every 30k miles rears lasted 40 or a little better. My trucks were always hooked to a trailer I pulll across the US working in mines, refineries, and other chemical plants. We had 4 2005 duramax 3500 trucks. All of them fell apart with less than 120k miles on them. Mostly injector , fuel pump, and electrical issues. My truck and trailer ways 23,000 plus lbs. I would drive 1k miles a day at times. Then work in plants 60-80 hrs a week. I use my truck for an office when I need to. The duramax just wouldn't put out like the cummins did. It pulled a little harder, but down time and fuel mileage sucked. We are now have a new fleet of 2010 cummins. So I am curious how they will be. I get my new truck in a few months. Mine will be a 2011.
Every front bumper on our durmax trucks started falling off. Interstate 10,40,90,and a host of others has bad pot holes that eat the gm trucks up. My duramax never overheated tho. I would leave it running all day ideling in the desert in Ca working at the mines, and also leave it running all day while in Canada keeping the heater on. Which reminds me. The heater controlls went out twice. So did the blower switch . I never abused any truck I had either. My trucks always lasted the longest in the fleet. The duramax broke a turbo bracket twice some how. And I had to have a water pump at 100k miles. Anti lock system gave me troubles all the time.
Sorry, this turned into a gm rant. didn't mean to. Just I work nation wide and use my trucks. I know what was dependable for me. I sure don't want to be broke down 50 miles from anything. Out west, you can go for miles and see nothing but antelope, elk, wolves and no service stations. Up in Canada you have a serious bear problem when you get out in the country. I had to learn quick about the turn the key on and off like 3 times, then push the fuel pedal like 4 times to be in a limp mode to idle to a service center. Glad my duramax is duradone. Never again. Not for hard towing and severe duty working. It won't keep up with the big boys.:S:
