Overhead console problems
595 views 12 replies 6 participants last post by  codeten44
My mpg, temp, compass screen quit. Overhead console lights work, with door or switch. Purchased another screen, it came and went for a few days and then quit also. The key fob quit working about the same time? Maybe?! Where does t power come from for it?
#5 ·
Well, no info on the particulars on your truck,(year etc.) , a signature would help. I can just suggest consult the FSM for your year. Wiring and explanations of the different levels will be in there. The different lines had differing CTM's which I believe, after grounds may be your issue.
#7 ·
Factory service manual, central timer module (under center of dash). FSM's downloadable on this site, or paper available from Genos. Either way you should have one.
#9 ·
Check the ground in the console for good no resistance ground. Any other shifting or gauge issues? Codes? Other than maybe ground the console and lights are all different circuits.
#10 ·
Polithera of problems is a guarantee of a ground system not working, which is
a standard option with these trks. (congenital )
The body module is about where you right knee is only under the dash plastic. BTDT
#12 ·
I had no bus, *intermittent problems, Bells/chimes and buzzers going off, and seat belts that would not unlock.
On and off oil pressure.
Could not scan codes.
SOOOoooooo I redid all the grounds under the hood.
Cut the wires back about 3 to 4 inches to clean copper, soldered and crimped tinned ends on...blah blah
This has fixed most of my problems .
The one left is no dash lights.
I am thinking that this will be another light switch....maybe .
Replaced cables with Marine tinned.
* too many to remember.
