Last couple of months my truck has been sporadically very hard to start. Usually it's a hot-start problem, but also has occurred after sitting for a day or two. Items of note:
1) electric in-tank pump - can't be a vac leak
2) electric fuel-pressure-gauge shows 25-ish psi as usual - verified with mechanical gauge mounted under hood - both gauges metering pressure at IP inlet, so I presume this can't be a clogged filter
3) cranks like crazy with no suggestion of ignition - I usually have to give it a little pedal, but no amount of pedal makes a difference when it's doing this
4) I'll crank for 5-10 seconds, then stop when this happens, observe pressure-gauge, see that there is indeed pressure, then try again
5) typically it's about the fourth session of cranking that starts it, taking maybe 1-2 minutes, occasionally more
The 'tork-tek' fix, I take it, would be reasonable if I were seeing much lower pressures, right? Any reason I'd see the kind of pressure I see at the IP inlet and still gain benefit from a tork-tek?
