Progressive means you can ramp up or down or fluctuate (for some reason) the amount of spray you need/use/want based on X Y Z parameters. Typically RPM and boost to the dependants you use. So for instance, you can make it start off at 5psi boost it sprays about 5% then ramping up to 50% giggle gas at 20psi boost and then to full 100% go juice once you touch 50psi (or whatever your choices are). I personally am going to still run jets even tough you do not need to just because I'm a little paranoid about things. This will probably only last for a couple months before I say screw it and just do the normal thing of no jets as the guy implied on pg one, but since this progressive thing is new to me i dont trust it *yet*.
Now a NON progressive kit is a light switch, on or off and nothing in between. this is then you get the most "hit" and can cause the most damage. can spray a forged SBC with a 400hp shot of spray, if you do it progressively, whereas if its just a single stage normal spray, that motor will experience 400hp to 800hp jump in a split second. that's when you get awesome noises and cool sparks and usually the crowd goes nuts too! As will your wife when she sees the bill to fix it! lol Now if you start spraying that motor starting at 2000 rpm and ramp up the spray to be 100% at 8k RPM. (i'm just using numbers as a hypothedical, lets not get into building a nitrous huffing mouse motor please)
as for when you inject, just play with it. this is going to be some serious butt dyno tuning at its best. for the first bit just start small/slow. have it spray maybe 5% at 10psi and ramp upto about 30% at 50 psi and see how it feels. then judging on how it pulls/spools you'll know where you want more or less. you might want it to ramp up quicker at first to help the twins light and then once the twins take off maybe back down the ramp rate. its all gonna be seat time and just have fun. unless you wanna go for a big number, then you make it ramp really hard really fast to try and spike it. but this is a solid cheaters tactic.
It always cracks me up when people make comments on how dangerous nitrous is for engines. What's funny though is if you do a little research I almost guarantee you will find that it is incredibly safe when used in a diesel application. Gasser, now that is a completely different story. Just don't be that guy spraying the turbo on the dyno and you'll be fine.
You will hit a point of diminishing return before having to worry about blowing something up or spraying too much. If and only if you are built for the application. Main focus here will be the head. Bottom end should be fine with a vp's power range even with nitrous. Also keep in mind that the nitrous is only there to help effectively burn what fuel you are injecting. So again you will eventually hit a wall when injecting nitrous.
Nitrous can be dangerous or it can be just fine. everyhting in moderation is fine. you can run a motor with no oil, you do every time you start it, but only in moderation. you can run a crap load of spray, but only for a little while. Just depends on how you do it :thumbsup: ^^^ this man speaks the truth tho, you can only make the power you have the fuel for.
